- Sat Jun 18, 2011 5:05 pm
#259933
so i found a dirt cheap k20a3 full swap (engine, trans, wiring, ecu, axles etc), and i was wondering what i would need exactly to get it up and running?
i know the a3 is not a very typical swap because of the low power but its cheaper than a b18b swap here locally.
thanks
thanks
and congrats on the k. best way to run that motor is get your self kpro. get a good header. skunk 2 stage 2 cams. and upgrade your injectors, throttle body and fuel rail. But don't put a A2 head on it, you would just be wasting your time. and hasport should sell swap mounts for that motor.
