- Mon Mar 18, 2013 11:29 pm
#328889
Me and a friend is into an argument about kswap with 6 speed he says it can't be done unless you take a chunk out of the fire wall is that true or not
- Tue Mar 19, 2013 12:20 am
#328891
only thing that needs removing iirc is the gearbox mount on the chassis. i think to put a k20 in an ef civic the firewall will need a 'tap'
- Tue Mar 19, 2013 3:09 am
#328905
Alright thanks I knew he was wrong but he did a k swap with a friend a couple of years back so he thinks he knows it all
- Tue Mar 19, 2013 11:42 pm
#328965
Yeah it had me worried cause I found a k20a2 for $300 and I'm trying to get it before its gone even though its probably trashed but I could probably build it up cheaper then then buying a running one then and building it up
- Tue Mar 19, 2013 11:50 pm
#328968
if it seems too good to be true, it usually is.......
they go for £1000 plus over here
92civicEGsedan wrote:Yeah it had me worried cause I found a k20a2 for $300 and I'm trying to get it before its gone even though its probably trashed but I could probably build it up cheaper then then buying a running one then and building it up
- Wed Mar 20, 2013 12:01 am
#328970
If it is oh well $300 is a good k20 furniture piece for my room till it could be rebuilt and yeah it's like $1500+ where I live
stubrun wrote:92civicEGsedan wrote:Yeah it had me worried cause I found a k20a2 for $300 and I'm trying to get it before its gone even though its probably trashed but I could probably build it up cheaper then then buying a running one then and building it up
- Wed Mar 20, 2013 12:13 am
#328971
Also with EK chassis i believe the rear mount bracket hits the Steering rack so an EG rack will need to be swapped in.
Team XXX Racing/WGHonda
- Wed Mar 20, 2013 12:20 am
#328974
I hate EKs they are just so ugly to me EGs FTW!
Eg6H2D wrote:Also with EK chassis i believe the rear mount bracket hits the Steering rack so an EG rack will need to be swapped in.
- Wed Mar 20, 2013 12:32 am
#328977
exactly
92civicEGsedan wrote:Eg6H2D wrote:Also with EK chassis i believe the rear mount bracket hits the Steering rack so an EG rack will need to be swapped in.
exactly
- Wed Mar 20, 2013 12:56 am
#328983
My uncle got a ek coupe today so yeah let the hate begin haha
stubrun wrote:92civicEGsedan wrote:Eg6H2D wrote:Also with EK chassis i believe the rear mount bracket hits the Steering rack so an EG rack will need to be swapped in.
exactly
