- Thu May 12, 2011 2:58 pm
#254919
does this sound feasible to you guys?? its a fault with an ECU that has occured...
"I found that transistor which is burned is named as Q31 and it controls purge evap solenoid, the problem appears if you are switching IAT and purge evap solenoid connectors and vise versa, the consiquences are melted IAT and transistor no. Q31"
