ECU, Wiring, Sensors
By EGCiviCKid
#303537 ah yes i read about the dizzy do i have to swap it for an obd1 dizzy?
and i already got the haynes manual i shall have a browse of that :thumb:
#303561 If you can get an OBD1 dizzy that bolts to the B16a2 head, then that would be an easy way to do it. :thumb:
I don't know which B series dizzys fit which heads though.
By EGCiviCKid
#303634 thanks for your help teal i got it sorted now! :thumb:
By EGCiviCKid
#303831 ok so my d15b2 dont have any injectors? what now :?
#303841 Oh, carb'd motor! Well now you might want to get an OBD1 harness from a fuel injected motor (D16z6, D15b7... not sure what motors they had avail in the UK but you'll probably want one with a 4-wire o2 sensor for a direct swap onto your B16a2)
By EGCiviCKid
#303843 ok sweet! will i still have to swap plugs for alternator and distributor and wire v tec??
EGCiviCKid wrote:ok sweet! will i still have to swap plugs for alternator and distributor and wire v tec??
Yes Yes and Yes... although if you get a D16z6 harness, it will already have the 2 plugs wired up for vtec :thumb:
By EGCiviCKid
#303859 time to hunt down a z6 harness 8)
thanks teal! :thumb:
By EGCiviCKid
#303895 i have found a d16z6 Engine Loom, Under Dash Interior Loom, Interior Fuse Box, Engine Fuse Box & Main Relay for sale
do i need all of it in my case or just the engine loom? :thumb:
By EGCiviCKid
#303922 if my civic is obd0 im guessing i need the obd1 loom as well as obd1 engine harness?
but do i also need fuse boxs etc ??
By EGCiviCKid
#304009 ok ive been told lsi is obd0 dpfi in the uk so:
if i get a d16z6 engine harness
this ecu with a b16a2 basemap http://h-tune.co.uk/index.php?route=pro ... uct_id=717
this conversion harness http://h-tune.co.uk/index.php?route=pro ... uct_id=721
every thing will be plug and play except the little bit of wiring for the alt and dizzy and vtec to the engine.
am i going along the right lines here lol ???
thanks :thumb:
