ECU, Wiring, Sensors
By joba356
#65183
teal_dx wrote:I had to extend some of the wires on the sides, the oned that run through the fender & to the wipper motor. The rest I did not need to extend except for the 02 sensor. rather than mess with the oem shielded o2 sensor wires in the engine harness, I made an o2 harness extension that plugs into the engine harnes on one end, and the o2 sensor on the other end. I would recommend not changing any of the wires that use the factory shielding. That would be the o2 sensor wiring & distributor. Anything else you can add a little if you need to.
Thanks for the info, will be taking out my motor in a few weeks to do this, trying to get some tools to shave the bay also, will post up progress
By joba356
#65185 Another question i have is, to bring the bake lines inside, did you simply undo them and redid them inside or did you have custom some of the lines to reroute them in there, looks like you have 1 line that looks new, also where did your route them through? Thanks
#65186 the brake lines are in this thread:
http://civic-eg.com/viewtopic.php?t=91
The 2 for the rear I re-used the original. The front 2 are new line, as are the 2 lines from the MC to the proportioning valve.
I enlarged the firewall hole from the heatercore and ran everything through there.
By joba356
#65188
teal_dx wrote:the brake lines are in this thread:
Thanks for the Info, looking foward to doing this, great help :thumb:
By a_CoUpE
#65695 ok when tucking where do you guys hide the wire harness plugs? the ones for the passenger and driver side, liek for the lights, the big gray plugs where do you guys place those?
By LucSTR
#70890 Sweet a$$ job man. i get my 94 coupe in a couple of days and this is going to be the first thing i do. one of my buddies has done a mild tuck on his 96 civic so he is going to help me. what kind of paint did you use?
By itzstephens
#77774 Hey sorry to jack in on your thread, Just wanted to let you know that i read this thread about a month ago and it really inspired me to do a full tuck on my car, which is now finished and i just primed the engine bay today and am painting the whole car next weekend. Just not to sure on wich inline fuel filter to use
rushvillejdmracing wrote:hey i just want to tuck my head light wires what type of wir should i use thanks
no need to re-wire, just re-route them through the fender area :thumb:
By blockustomz
#85315 thanks alot teal for making this.. im doing this for my eg right now. only problem is my engine is a gsr and mine is staying inside while i tuck.. im having alot of fun doing it but to be honest seeing this makes me wanna get it down even more. your bay is fukin hot looking. but did u have to use the catch can or did u do that for the turbo?. ill start a build thread soon.
