ECU, Wiring, Sensors
By pancake
#168951 hey guys,
i just put some philips xtreme power bulbs into my eg.
the right hand light is quite dimmer compared to the left side,
do i need to upgrade the wiring harness, or is it some other problem
since the philips bulbs are 60/55w, i thought that it would be able to support them.
any suggestions?
cheers!! :wink:
ps: can provide picture if needed!
By DontHateonEG8
#168954 the same happened on my buddies hid kit on his integra. the stock wiring and relay was not able to support hids so he needed to get a relay kit. the same is most likely applied to you to. good luck!
