B18a1 Update
UPDATE
ok iam still get a Cel code 3,16
i have changed the map sensor 3 times and still the same thing, and the car supputers hard and sound like it is missing. lol and somtimes cel code 14 comes on.
i have check the wiring all the way back to the ecu for the map sensor and its fine. I have check to see if i have had the tps and the map sensor plugs switched around and i dont. But it would not idle it would just bog out so i changed the map a 4th time cuz i have so many b sereris tb layong around and it idled but sputterd what could be the deal. also iam running a del sol non vtec ecu cuz my friend said it will work. what could be the deal.
also iam using a 94 dx harness into a 92 dx
