Fog lights stopped working, HELPPP
Sun Dec 05, 2010 6:59 pm
by chaosdriving
Hello everyone, well my fog lights were working gret for the past 3 or 4 monthes, then all of a suddon they stop working, i checked the fuse and it was fine, ai even changed it just incase it was blown and i didnt see it and still nothing. When i hit the switch, the relay clicks. I tucked the relay underneath my frame so water got to it, so i opened it up cleaned it up a little, then put it back together and it worked! then as soon as i tied it to the frame again it stoped working. Would this be the relay since its corroted soo bad even tho it still clicks when the button is pressed? thanks.
Tue Dec 07, 2010 9:34 am
by Ajax1989
try replacing the relay
but also check the ground for the foglights them selfs
Sun Dec 12, 2010 3:04 pm
by chaosdriving
replaeced the ralay and at first it did not work, then i went for a drive, and accidently hit the switch on and they accually started working. Mabey they needed time to warm up on the new relay? lol thanks for your help
Mon Dec 13, 2010 1:22 am
by ImThaBean
If they just fired up, you may want to double check the ground and all connections just in case. You may have a loose wire somewhere.
