need urgent ecu help
i just did a z6 swap on my 92 i want to hook up the v tec i have the new computer. i looked at teals mini me swap wich tells how. http://www.civic-eg.com/viewtopic.php?t ... sc&start=0 and i have the pin locations http://technet.ff-squad.com/wiring/obd1 ... matics.gif
but still i havent found anything about how to actually put the wire into the ecu? can someone help me? i dont want to fry anything i just put out alot of money on this swap.
if i was looking at it right for example on d there was wires in 1,2,4,and 6. but on 3 and 5 there was no wires. and the wire in slot 6 is like orange with a blue stripe.idk maybe someone before put a diff wireing harness in it? not sure. ok wout it be better to use but connecters at the shok tower to attatch the wires? or should i try to pull the pins from anotehr harness and use pins? i have another harness i could so it with but my friend kinda needs the harness to i need to try to save it if possible
