OBD1 motor/ecu into OBD2 car - making a checklist
I'm looking at getting an OBD2 1996 integra (OBD2a to be exact).
I am going to have a fresh built boosted D16z6 & S300 P28 available and want to know what it will take to put this in a 96 integra.
- OBD2a to OBD1 conversion harness, of course
- Now, do I use the engine harness from the '96 motor or from the OBD1 D16z6? (Not sure if an OBD1 engine harness will plug into the shock tower plugs on an obd2 car - I wouldn't think so)
- So assuming I'm using the OBD2a engine harness, I know I'll have some extra plugs (secondary o2, CKF...)
- I'll need a OBD2a to OBD1 distributor harness
- The D16z6 has DSM 450cc injectors which use an OBD1 injector clip. I'll need to hardwire OBD1 injector clips in place of the OBD2 ones on the 96 engine harness, right?
I have an idea of everything else, mounts, axles, linkage... just want to be sure about the wiring
