- Mon May 14, 2012 6:22 am
#304835
ok well i have a 92 civic sedan and my speedo and odometer and the dash lights dont work but my tach, fuel and temp works what could be the problem?
- Mon May 14, 2012 7:44 am
#304842
yeah i have dimmer switch and i did pull out my cluster and checked my connections but i didnt check the ground and i dont know which would be the ground
- Mon May 14, 2012 11:59 am
#304854
ok ill go check them when ever it quits raining
- Wed May 16, 2012 4:25 pm
#305105
i saw nothing that looked like that on the steering column
- Sat May 19, 2012 7:27 pm
#305452
i have still yet to figure out this poblem
- Sun May 20, 2012 4:10 am
#305495
try new bulbs?
- Sun May 20, 2012 4:17 am
#305498
all of the bulbs look brand new, no dark tint to them as if they had blown or anything
- Sun May 20, 2012 4:30 am
#305499
i think u should atleast try the bulbs that do work on diff holes and if none light up then you must have a bad circuit panel happen to me so i just jumped a wire for the start to a light bulb socket
- Sun May 20, 2012 4:48 am
#305503
none of my bulbs work that supposed to light up the cluster when your head lights work and i dont have any friends with civics around here they all drive trucks
- Sat Jun 02, 2012 6:45 am
#307040
Well I fixed the problem with the lights in the dash, it was my dimmer switch all I did to fix it was connect the red wire and black wire and BAM lights worked
