gauge cluster problems
PostPosted: Mon May 14, 2012 6:22 am
by 92civicEGsedan
ok well i have a 92 civic sedan and my speedo and odometer and the dash lights dont work but my tach, fuel and temp works what could be the problem?
PostPosted: Mon May 14, 2012 6:30 am
by EJ1_MK
did you pull your cluster and check the connections as well as the ground that is directly behind it. Other than that the lights could be the dimmer switch if you have one. Or check the bulbs.
PostPosted: Mon May 14, 2012 7:44 am
by 92civicEGsedan
yeah i have dimmer switch and i did pull out my cluster and checked my connections but i didnt check the ground and i dont know which would be the ground
PostPosted: Mon May 14, 2012 9:18 am
by EJ1_MK
there are two one is a 10mm bolt holding it on the steering column on the left side toward your driver door and there is another on the right side which is just a slip on connection. Both are black wires.
PostPosted: Mon May 14, 2012 11:59 am
by 92civicEGsedan
ok ill go check them when ever it quits raining
PostPosted: Wed May 16, 2012 4:25 pm
by 92civicEGsedan
i saw nothing that looked like that on the steering column
PostPosted: Sat May 19, 2012 7:27 pm
by 92civicEGsedan
i have still yet to figure out this poblem
PostPosted: Sun May 20, 2012 4:10 am
by HungRealLow21
try new bulbs?
PostPosted: Sun May 20, 2012 4:17 am
by 92civicEGsedan
all of the bulbs look brand new, no dark tint to them as if they had blown or anything
PostPosted: Sun May 20, 2012 4:30 am
by HungRealLow21
i think u should atleast try the bulbs that do work on diff holes and if none light up then you must have a bad circuit panel happen to me so i just jumped a wire for the start to a light bulb socket
PostPosted: Sun May 20, 2012 4:35 am
by dbrooks
Try putting a friends cluster in and see if it works.
PostPosted: Sun May 20, 2012 4:48 am
by 92civicEGsedan
none of my bulbs work that supposed to light up the cluster when your head lights work and i dont have any friends with civics around here they all drive trucks
PostPosted: Sat Jun 02, 2012 6:45 am
by 92civicEGsedan
Well I fixed the problem with the lights in the dash, it was my dimmer switch all I did to fix it was connect the red wire and black wire and BAM lights worked
