cel issues
so the kid i bought the car off took the check engine light bulb out. put another bulb in. came out of another car. but still cant get the check engine light illuminate. is there another wire he might of cut to hide it? im doing this in the ran so the faster i finish the better. 95 civic ex
also cant get the brake switch to light up. one of the other missing bulbs it looks light.
key on in the second position. check engine light should test. but nothing.
i jumped the plug. (blue two pin connector next to ecu) SRS light flashed only.
checked the back up fuse used to reset the ecu. beside that there arent fuses to the cel or brake switch itself. unless this kid cut wires. is there a wire directly to the CEL/Check Engine light??
