B16 high idle and over fueling..
Hi Guys,
I have just put a OBD2a B16a2 into my OBD0 Non vtec LSI
my setup:
chipped p28> 0bd1 sir interior harness>obd1 vti engine harness
i have modified the obd1 VTI Engine harness
*swapped injectors for obd2
*rewired dizzy and alternator for obd2
*extended the iat sensor
When i came to install the MAP sensor, i used the original OBD0 interior harness for the map sensor wire and plug and spliced it into the shock plugs of the sir obd1 interior harness.
i done this because there wasn't a spare plug on the obd1 engine harness, as the map sensor was originally located on the fire wall/ now on the throttle body.
the engine starts up and sounds ok... it has a slight high idle and its massively over fueling.
i have been told by my mechanic the sensors need wiring up correctly?
would this cause these symptoms?
im starting to doubt things i have done now, just need someone to lemme know im on the right tracks and help me sort this bloody over fueling and high idle then i can put it in for the MOT
hope ya'll can help!
my setup:
