Major Electrical Issues!
I have a 92 DX Hatchback with an F20B swap..
At first start-up the car runs fine and sometimes, not often, itll bog and die after it shuts off that initial time when I go to turn it back on. I have to wait a moment for it to start it for it to stay running, sometimes it turns back on faster if i play with the fuse box under the dash (I dont actually know if this helps or not...)
Then the turn signals stopped working.
After pulling the dash out to do an Integra dash swap, none of the lights would work on my combo switch BUT the tail lights would stay on, no other lights would work other than the highbeams when I pull the lever in.
On the wiper combo switch, the wipers are always on low. Turning the combo switch does nothing but pulling it works (with the water jets).
Now I go to start it but it doesnt crank at all. I hear the fuel pump buzzing but nothing happens when I turn the key... I've checked all the fuses and engine bay grounds and they're all good.
Would replacing the whole dash wiring harness solve my problem???
