- Mon Feb 17, 2014 8:00 am
#342734
Hi Guys,
hope someone is able to help me with an issue im having.
I have a EG4 (import), it was a Auto carbureted D15, which i have converted to OBD1. I used a local OBD1 harness from a B18B, then created a Jumper harness to OBD2A for my JDM P73 ecu (DC2 R). the car has a full b18c Type R swap as I had purchased a front clip.
So the issue i have is, High Idle and CEL. code 20, which is ELD.
From my understanding, the car idles higher to produce more volts as it detects its not getting the correct amount?
Issue is i do not have an ELD in the fuse box as this car never came with it, is there a fix for this? Surely other b18c swaps have had this?
Here is the pin outs i used for the Jumper harness
OBD-2a || OBD-1
A01 - INJ #4 || A02 - INJ #4
A02 - INJ #3 || A05 - INJ #3
A03 - INJ #2 || A03 - INJ #2
A04 - INJ #1 || A01 - INJ #1
A05 - EMPTY
A06 - PO2SHTC || A06 - PO2SHTC
A07 - EMPTY
A08 - VTEC || A04 - VTEC
A09 - LG1 || A26 - LG1
A10 - PG1 || A23 - PG1
A11 - IGP1 || B01 - IGP1
A12 - IACV || A09 - IACV
A13 - EMPTY
A14 - EMPTY
A15 - EMPTY
A16 - FLR Fuel|| A07 - FLR
A17 - A/C Ctrl|| A15 - A/C Ctrl
A18 - MIL || A13 - MIL
A19 - ALTC || A16 - ALTC
A20 - ICM || A21 - ICM
A21 - EMPTY
A22 - LG2 || B02 - LG2
A23 - PG2 || A24 - PG2
A24 - IGP2 || A25 - IGP2
A25 - EMPTY
A26 - EMPTY
A27 - FANC || A12 - FANC
A28 - EMPTY ||
A29 - EMPTY ||
A30 - EMPTY ||
A31 - EMPTY ||
A32 - EMPTY ||
C01 - EMPTY
C02 - CKP P-side || B15 - CKP P-side
C03 - TDC P-side || B13 - TDC P-side
C04 - CYP P-side || B11 - CYP P-side
C05 - A/C switch || B05 - A/C switch
C06 - STS || B09 - STS
C07 - SCS || D04 - SCS
C08 - K-line || D07 - Diagnostic
C09 - EMPTY
C10 - Volt/backup|| D01 - Volt/backup
C11 - EMPTY
C12 - CKP M grnd || B16 - CKP M grnd
C13 - TDC M grnd || B14 - TDC M grnd
C14 - CYP M grnd || B12 - CYP M grnd
C15 - EMPTY
C16 - PSPSW || B08 - PSPSW
C17 - ALTF || D09 - ALTF
C18 - VSS || B10 - VSS
C19 - EMPTY
C20 - EMPTy
C21 - EMPTY
C22 - EMPTY
C23 - EMPTY
C24 - EMPTY
C25 - EMPTY
C26 - EMPTY
C27 - EMPTY
C28 - EMPTY
C29 - EMPTY
C30 - EMPTY
C31 - EMPTY
D01 - TPS || D11 - TPS
D02 - ECT || D13 - ECT
D03 - MAP || D17 - MAP
D04 - VCC1 MAP || D19 - VCC1 MAP
D05 - BKSW || D02 - BKSW
D06 - KS || D03 - KS
D07 - PH02S || D14 - PH02S
D08 - IAT || D15 - IAT
D09 - EMPTY
D10 - VCC2 || D20 - VCC2
D11 - SG2 || D22 - SG2
D12 - SG1 || D21 - SG1
D13 - EMPTY
D14 - EMPTY
D15 - EMPTY
D16 - ELD || D10 - ELD
Thanks, any help would be appreciated
OBD-2a || OBD-1
A05 - EMPTY
A07 - EMPTY
A13 - EMPTY
A14 - EMPTY
A15 - EMPTY
A21 - EMPTY
A25 - EMPTY
A26 - EMPTY
A28 - EMPTY ||
A29 - EMPTY ||
A30 - EMPTY ||
A31 - EMPTY ||
A32 - EMPTY ||
C01 - EMPTY
C09 - EMPTY
C11 - EMPTY
C15 - EMPTY
C19 - EMPTY
C20 - EMPTy
C21 - EMPTY
C22 - EMPTY
C23 - EMPTY
C24 - EMPTY
C25 - EMPTY
C26 - EMPTY
C27 - EMPTY
C28 - EMPTY
C29 - EMPTY
C30 - EMPTY
C31 - EMPTY
D09 - EMPTY
D13 - EMPTY
D14 - EMPTY
D15 - EMPTY
