By 1-low-92-EG-Sedan - Sun Jan 04, 2015 6:39 am
#350714
ok so i have a 92 sedan with a remote start and want to wire up the rear defrost to go on with the remote start im not really sure on how to go about wiring it all up..there is a negative trigger wire from the remote start module ..but i have no idea what wire to tap into from the defrost switch(or if i should even tap into it there) im also not sure if i need a relay to make the trigger wire a positive instead of a negative .. any help would be greatly appreciated thanks in advance
Last edited by 1-low-92-EG-Sedan on Fri Jan 09, 2015 3:12 am, edited 1 time in total.
EG8 Build: http://civic-eg.com/viewtopic.php?t=20985&highlight=
EK Build: http://civic-eg.com/viewtopic.php?t=257 ... highlight= SOLD
#10 of The Civic-EG.com Ferio Squad
youll never have to wonder if its on or actually turn it on when you use the starter. and its not like itll overheat if you use it in the summer
