ECU, Wiring, Sensors
#69878 Well, I went down stairs to try to start the car to go to work, before I knew I didnt have to, and nothing happened. I got no lights, radio or anything. Then it wouldnt start. its like the battery wasnt there but it was. I pulled out the ECU and checked it and its not looking so good, but that shouldnt stop power from flowing all together should it? If I can get pics up I will, but I need to get batteries first. The ECU looks like it did that last time I had to replace it.
Now I just need to figure out why I cant get any accessory power. any help?
#69881 am i safe to assume that you've tried boosting the battery? or tried another one? doesn't hurt.
havent tried that actually. Dont have anything to do it with. But I will, when I can get someone here with a good battery.
#69882 Looks alot like this. This is my other ecu that got water in it.
By marvinp8700
#70011 check the back-up and ecu fuse under the hood. i got water in my old hatch and it popped the ecu fuse.
#70110 Found out what it was.
Bad battery and ecu. Swapped both and Im running again. THough my battery light does come on after 2k rpms....
By Method
#70114 alternator.
