- Fri Oct 03, 2008 4:28 am
#72535
I went to NAPA today, looking for a new battery. turns out the battery was about 80 bucks. I said screw it. I went ahead and bought a bigger battery (for a normal car) for $40 and relocated it to the trunk. here's where it gets fun...
I turned the car on. Perfect. vah vah vroom. turned on like I just bought the car yesterday. Amazing. I realized I didn't notice whether it flashed a low battery warning when i turned it on, so I quickly turned the key to the off position and promptly turned the car on again. I screwed up. The car had not fully powered down so the engine came back to life instantly, and I still had the key in the cranking position and the car made the awful errrrrrrrrrrrrk sound. Then it died. I mean EVERYTHING. I had a brainfart (a big one) It happened so fast it took me a second or two to remove the key from that position once the sound started.
I tried turning it on seconds later. nothing. absolutely nothing. tried the dome light. nothing. headlights. same thing. I then removed the negative on the battery and reconnected it. I heard a beep so ran to the driver's seat just to see all of the red lights on my cluster lighting up. couple seconds later, poof. gone. still wouldn't crank. I tried the old battery, and the portable battery charger I have. nothing works.
my thoughts are....
ECU?
Fuse?
Starter?
I need all the help I can get.
my thoughts are....
ECU?
Fuse?
Starter?
yea i found that odd too. ive never heard of the entire power of the car failing because of a starter.
