ECU, Wiring, Sensors
By Josiah
#73862 Stock they are 10 amp, I have stock headlights and I have done nothing with the headlights and I blew that fuse so I put in a 15, 20,and 25 and they all blew, I don't want to do a 30 that might start a fire so what do I do? :?
By jmsplitfyre
#73914 I'm not the pro with wiring but I blew a fuse when I was fixing my amp wiring and I forgot to tape up my positive wire then it touched the body, then Poof!
So I'm guessing there's a wire there or some part from your headlight that's touching the body. :?
By Josiah
#74000 found a wire rubbed on the motor mount, :thumb: taped and loomed, thanx!!
Josiah wrote:Stock they are 10 amp, I have stock headlights and I have done nothing with the headlights and I blew that fuse so I put in a 15, 20,and 25 and they all blew, I don't want to do a 30 that might start a fire so what do I do? :?
putting a bigger fuse in place of a smaller one because it is blowing is a really bad idea. This can fry your wires or sensors instead of an easily replaceable fuse. :thumbdown:
