ECU, Wiring, Sensors
By BAXTER_EJ1
#76882 My dash is currently maxed out in terms of switches and buttons. I have sunroof, cruise control, etc. as well as an aftermarket alarm that uses the stock fog light switch location for its LED indicator.
I'm really interested in putting in OEM Fog Lights, however, I LOVE the look of the rear fog light switch on the E-Brake Housing.
Has anyone ever wired their fog lights to a rear fog light switch? I'm wondering what the harnesses are both like and if it might just be plug-n-play? Worst case scenario, I can drop the LED Indicator and use the stock fog light switch in its intended location.
By asianrob
#76895 they do have the oem foglight switch on the armrest along with the rear foglight switch too... also seen the Half switch(moves antenna down 1/2 way for areodynamics) and also pole switch too
By Classiccarsrule85
#76916 yea you could get the center console button or just move the little led light for the security system
By BAXTER_EJ1
#76922
DC4rob wrote:they do have the oem foglight switch on the armrest along with the rear foglight switch too... also seen the Half switch(moves antenna down 1/2 way for areodynamics) and also pole switch too
Ah! Every auction I've seen for it says rear fog light, but you never can trust egay.
Now I just have to try to find a reliable supplier for an actual OEM Fog light assembly with the harness and everything :lol:
By asianrob
#76924
ha yea sometimes they are hard to find and then some times out of no where they have a shit load of them
