- Wed Apr 20, 2011 5:35 am
#251320
so i've read up about this and there's a couple of things i don't get. If you're suppose to take out the black wire, where do you put it? and how is the switch suppose to work if you're going to have an empty slot in the main relay? i don't understand the wiring and how you're going to put the switch into the main relay harness.
heres a diagram i made. just pay attention to the single switch. pretend the PLUS sign is the main relay and the other end is the ground(ground symbol drawn)
so basically for a kill switch, u dont remove any wires, u just add a switch in between the circuit, switching the switch to ON completes the circuit, switching it to OFF creates an open loop meaning ur circuit is not complete resulting in ur main relay not working at all. pretty simple. but theives know all this allready and if they find out u put a switch in between ur black wire but they cant reach ur switch somehow all they can do is cut ur black wire from the main relay and ground it themselves and there goes ur ride.
i hope i have cleared a couple things about kill switches
off topic: this might be freaky for u but i kno who u are LOL, u might not know me at all, i kno ur cousin whitley
EDIT: i see that ur pretty new to the car scene, heres something i HIGHLLY HIGHLY RECOMMEND, it will probably answer almost all ur questions i guaranttee it.
here go buy this book:
