- Thu Apr 28, 2011 1:12 am
#252699
maybe it is different in canada but here in usa yellow is constant 12v memory, red is switched ignition power.
orangeEG wrote:LSVTIEG wrote: now with the key off touch the other end of the test light to the yellow wire. the light should come on as this is the constant wire that supplies power to the radio to maintain its memory.
next test the red wire with the key off then on. the light should only light up with the key on. since you are having problems when you turn on the lights on go ahead & turn on the lights if everything is correct so far. if the light turns off with your lights turned on you found a problem if it stays on move
Correct me if I'm wrong but I've been doing car audio for a couple years and studying for my mecp certification and I think you might have gotten you constant 12V soured mixed up with your ignition source
Constant 12V source-RED
ignition source -YELLOW
Might be different for different company's or countries but here in Canada that's how it is
Rollin slammed Hondas since 1993
