- Mon Nov 03, 2008 4:55 am
#76990
ok i have no idea whats wrong.. i have a pioneer deck wired to a jl 500/1 amp. the amp turns on and everything but im not getting sound. i know is wired properly and the cabels are good. somthing to do with the signal from my deck. i plugd the rca to another deck in a diff car and it worked. so the amp is fine. then i put in a cheap amp in my car and it powered the subs. so why wont my deck work with the amp?????
- Mon Nov 03, 2008 5:21 am
#76995
So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
- Mon Nov 03, 2008 3:58 pm
#77017
when you have you your jl 500.1 hooked up in you car running off your deck run a set of speaker wire from the amplifier and put a multimeter to them and see if you are getting any sort of out put at all.
- Mon Nov 03, 2008 6:39 pm
#77034
yes i have a remote hooked up and the sub turned on. when i put my finger on the back of the deck on the rca outputs it starts to make sound. i toched a wire to the rca while still conected and toched the metal on the deck and it works. what the hell is it. bad ground?? i have had this deck for a while and it works with all my other stuff.. is ther somthing on the amp not hooked up right. its all powered on.
- Mon Nov 03, 2008 6:40 pm
#77035
you mean head unit to amp?? or am i missing somthing???
jmsplitfyre wrote:So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
- Mon Nov 03, 2008 6:56 pm
#77038
yeah try graounding it in a different place. when my subs stopped working that was the problem. but it could very well be your deck also
- Mon Nov 03, 2008 8:07 pm
#77044
Oh yeah, head unit to amp. My bad. And maybe you do have a bad ground since you were saying that it's working when you touched the rca's, etc.
egsedanguy wrote:jmsplitfyre wrote:So rca cable and amp is fine, did you check the remote wire? It's the blue wire from your sub to the amp?
