- Tue Jun 12, 2012 6:27 pm
#308032
I have been replacing my inner and outer tie rods and cant seem to get the boot to go on cause of a tight fit any suggestions?
- Tue Jun 12, 2012 7:19 pm
#308039
well after several minutes swearing seemed to help and i got it on but im confused.
I was putting the outer tie rod on the hub and when screwing the castle nut back on I can thread the nut way past the hole for the carter key before it even begins to be thight I was thinking the ball joint would get tight way before that and the castle nut should line up with the hole?
If it helps this is from orielys mastercraft pro brand
unless I loose a wheel bearing.
