- Fri Feb 05, 2010 3:21 am
#173358
i put wheels on it and now itz pulling to the right......i wanna lower it too....i found some eibach springs for like 64 dollars i think imma run with those n a blt
- Fri Feb 05, 2010 3:24 am
#173360
ad i kno im kinda gettin off subject but is there anyway i can find a set of struts for less than 300???
- Fri Feb 26, 2010 2:01 pm
#177958
yea go to tirerack.com they have a bunch of stuff to choose from i just got the koni str.t shocks on clearence last week for $60 a shock, they are not the best but definately an upgrade from stock.
1994 CIVIC Lx Camellia red pearl ( purple)
- Fri Feb 26, 2010 2:19 pm
#177960
do u guys no if the bushings work on blocks racing lca the oem work so i guess the energy ones work 2 dose eny one know 4 sure ?
- Fri Feb 26, 2010 9:16 pm
#178038
i just installed blox lca on my car and i dont believe they do (not shure though) however the bushing on the blox are impregnated with grapite they have a decent bushing in them already, i would say not worth the trouble to pess them out and replace them
- Mon May 24, 2010 9:36 pm
#196554
I just finished installing the complete kit, but the only question I had was on the strut mount bushings that go in the stock hat. Which direction should they go in? I've put everything together with them angling up/down (so kinda like -<0|0>-), but it seems really awkward.
94 Civic Si - 250k miles and climbing - DD
84 Toyota Celica GT - 1/3rd mile circle track race car (and parts car)
84 Toyota Celica GT - 279k miles - restoration/project car, future swap canidate
- Wed Jan 26, 2011 4:39 am
#235460
I just want to make sure this is for the front lower control arms
http://www.corsportusa.com/store/catalo ... ts_id=7541
- Wed Jan 26, 2011 4:53 am
#235468
Mine didn't have the metal sleeves like the ones in the pic... but I did mine almost 10 yrs ago. Maybe they changed since then
I'd ask corsport to be sure, that's why they're a sponsor on this site - to help members get the parts they need.
- Fri Apr 01, 2011 11:58 pm
#247668
I didn't happen to see this mentioned reading through. Does the energy suspension kit require new metal sleeves to be pressed in or are they just the rubber bushing? I don't know if the picture is exactly what you get in the kit but I only saw the metal inserts that the bolts go through not the sleeves.
- Tue Jun 26, 2012 2:55 pm
#309461
Yea whats up, well i remember sending you a message if you installed the suspension yourself! You said you got it done lol well i did the whole front end upper/lower/ control arm bushing and it was a pain in tnlyhe ass as you had told me, but i aint get your message til recently. i had my car up on a pair of jacks i used simple tools and it was my first time. simple tools
*Hammer
*Torch
*Grinder
*Small lttle saw
*decent flalt head
lol took me about 4-5 days due to not knowing what i was getting in too but soon as the 5th day hit got only two new bushing in for upper control arm. next day which was 6th i bang it all out and had a friend swing thru with a grinder which made it more easier to take out the factory shims to put in all the new enegry suspension. my front end is riding beautiful but still got a lot work to deal with but damn i was happy to get it done and back in with new axle new rotors new brakes...missing shocks//springs but heard coilover set is the best!!!!![/b][/b][/b][/i]
*Hammer
*Torch
*Grinder
*Small lttle saw
*decent flalt head
- Thu May 16, 2013 4:09 am
#331780
Got a bit of a pickle...I did this on the front of a DC Integra (guessing its the same as EG) and also did the rear trailing arm bushing (the whole bush with the metal pin not the rubber bush on its own) and now I'm getting quite a bit of knocking and banging noises from the rear end. It makes me nervous when driving thinking that something is going to come loose.
What could it be? I raised the rear from the middle with a jack and then each side separately with a scissor jack from the lower control arm, then I tightened the compensator arms, trailing arm bush and LCA bolts.
Compared to before the rear is about 1cm higher. Any suggestions?
- Thu May 16, 2013 6:15 am
#331784
Teal I hate to bring this way back from the dead but I made a post about bushings then found this and deleted it seeing as how I messed up on the wire tuck thing. lol. What did you think about the bushings when you first installed them and what do you think about them now quite a few years later? I have read on here that they are super stiff at first and the ride quality sucks, I actually kind of like that ride
, but how about now? Are you still running the same bushings?
MY vtec went BWAAAAHHHH!!!!!
No more honda ladies and gents :'(
- Thu May 16, 2013 11:34 am
#331786
Compared to old worn out O.E. bushings, these are more comfortable.
panic989 wrote:Teal I hate to bring this way back from the dead but I made a post about bushings then found this and deleted it seeing as how I messed up on the wire tuck thing. lol. What did you think about the bushings when you first installed them and what do you think about them now quite a few years later? I have read on here that they are super stiff at first and the ride quality sucks, I actually kind of like that ride, but how about now? Are you still running the same bushings?
