- Sun May 23, 2010 7:59 pm
#196340
iv got a hatch and iv had a few people tell me that my car rolls alot round the corners even though iv put coilovers on it :s im gona get hold of some front and rear strut braces and probably get stiffer springs for my coilys but cant see this makin a huge improvement over what iv already got? :S has any else noticed their civic to roll quite badly round corners??
- Sun May 23, 2010 11:00 pm
#196367
Mine was flat as a pancake through corners - you need anti roll bars
- Thu May 27, 2010 4:24 pm
#197192
iv been looking around and i cant actually find any :S iv got metallic red lower control arms so hoping to get similar coloured anti roll bars, anyone know of any??
- Thu May 27, 2010 7:23 pm
#197252
ya u can just paint em what color u want also..
- Fri May 28, 2010 2:26 am
#197316
Integra Type R front and rear sway bars.
/thread
/thread
Straight lines are for sissies.
- Fri May 28, 2010 2:47 am
#197319
you can get the oem front sway bar from a 93-95 ex coupe, si hatch or 94-2000 integra. they have plenty at the junkyards. for rear, if you go oem, you can can get that sway bar from 94-2000 integra also or one from 92-95 ex sedan if you can find one. if you plan to go bigger aftermarket one for the rear, you will need a subframe brace. ASR has combos of sway bar with endlinks, brackets anf brace. you can chose a sway bar size from 22 through 32mm
. getting some stiffer springs will be great too. strut bars wont stop the roll.
BoRIcuA y QUE!
BoRIcuA y QUE!
- Fri May 28, 2010 6:52 pm
#197498
you dont need a subframe brace unless your running like a 26mm bar n up. a 22mm will work fine but the sub breace does look nice and will help regardless.
ej2rey wrote:you can get the oem front sway bar from a 93-95 ex coupe, si hatch or 94-2000 integra. they have plenty at the junkyards. for rear, if you go oem, you can can get that sway bar from 94-2000 integra also or one from 92-95 ex sedan if you can find one. if you plan to go bigger aftermarket one for the rear, you will need a subframe brace. ASR has combos of sway bar with endlinks, brackets anf brace. you can chose a sway bar size from 22 through 32mm. getting some stiffer springs will be great too. strut bars wont stop the roll.
- Fri May 28, 2010 8:24 pm
#197510
ASR 24mm Rear set up with brace is awesome they also have a 32mm hollow bar set up for seriousness.
the 24mm ASR swar bar and brace set up is roughly 400 US dollars.
check it out.
http://www.jhpusa.com/store/pc/viewPrd. ... tegory=357
check it out.
- Fri May 28, 2010 8:27 pm
#197511
ya thats how i would buy them
EG6b20R wrote:ASR 24mm Rear set up with brace is awesome they also have a 32mm hollow bar set up for seriousness.
check it out.
- Fri May 28, 2010 8:40 pm
#197517
i never knew they made a 26mm. i thought it went from 24,, to the hollow 32mm. that's new to me.
ej2rey wrote:They also have 26mm hollow. But im in for the 32mm. The homie has an ek with the 32mm brace kit, that thing rides like its on rails.
