Project suspension build up ... input?
All right I'm done spending big money on my car this year. I have my suspension build pretty much planned out, but I'd like a little input (especially from the AutoXers here).
Anyway planned setup is as follows (keep in mind when offering suggestions this is a DD/AutoX setup ... might hit the drag strip a few times just to see how it does)
PIC select coilovers 10kf/8kr
-The springs are the same and as such can be swapped front to rear. Should I run the heavier springs in the rear?
GSR/Type R F/R sway bars (24mmF/22mmR)
-I will be getting the Beaks kit for the rear, so I'm not worried about fitment issues there. The question here is ... if I just get the proper mounting hardware (mounting brackets, endlinks, etc.) will the front bolt right up? Or do I need Integra FLCAs to make that work?
Custom traction bar from my tuner.
-Not sure that there are any suggestions that can be offered as far as this component is concerned, but if there is any input to be had ... I welcome it.
