r aftermarket lca's needed?
PostPosted: Tue Jan 18, 2011 11:14 pm
by 92hatchie
probably a nooob question.. are aftermarket lca's reaaly necessary ? besides them being lighter does it really benefit suspension?
so far i got k-sport coilover fron n rear strut bars. do i need anything else?
PostPosted: Tue Jan 18, 2011 11:50 pm
by JUICE
mostly bling but also because those bushings are usually shot and aftermarket LCA's are only a little more than the stockers
PostPosted: Wed Jan 19, 2011 1:11 am
by Cl9junky
If you want to get any kind of sway bar you need them unless you put some stock LCA's from a model honda that came with them stock IE Type R or if you car came with a stock sway bars already.
Plus the colored ones add 12.86 Whp and 56 LBS TQ. :lol: :lol:
PostPosted: Fri Jan 21, 2011 3:23 am
by Greasedmonkey
not neeeded at all.
but they do have their perks.
PostPosted: Fri Jan 21, 2011 7:21 pm
by Grat
only really benefits are light weight. some like the skunk 2 or function 7's come with multiple holes to adjust the tension on your sway bar. some come with poly or spherical bushings. the bushings in the cheeper ones like blox will get shot after a while
