EJ2 - GSR brakes and sway bars.
Well guys i need some of your help. i just joined the cite and i really like it
looks like people are helpfull and united.
I have a 94 DX coupe with upgraded GSR brakes all around. While i was at it i replaced some worn bushings, upgraded to brenbo drilled rotors and ceramic pads. The DX trim did not have sway bars, i figured since i have GSR sway bars sitting around doing nothing, they might help some once installed in the car.
Front is 24mm and Rear is 14mm.
now my questions are:
1- For the Front i'm thinking on getting this
bushings
already have this, but not sure if i got the right one???
End links
2- For the rear i have BLOX lower control arms. I'm thinking on getting this
BLOX adjustable end links
bushings.
i read somewhere online that is recomended to use the adjustable REAR end links with aftermarket LCA or atleast with Blox LCA. its this really true?
I'm also thinking about Rear sway bar fitment, i have a 3" exhaust so i'm not sure but i will mount mount it and see.
bushings
End links
bushings.
