Coilovers....
PostPosted: Wed Apr 11, 2012 7:20 pm
by jadeydrag0117
i installed coil-overs on my car a while ago, i haven't put any other suspension on my car so i'm all stock besides the coil-overs.
i'm riding approx. a 2.5 inch drop....and i'm wondering now does lowering your car do damage to any other parts besides the tires, (stock suspension parts)?
i just want to make sure i'm not riding around severely wearing out other parts cause i'm low....and the only thing i've heard you "should" get after lowering are cambers
but i'm fine with getting tire wear and alignments, just want to know if lowering causes any other problems.
PostPosted: Wed Apr 11, 2012 8:40 pm
Other than blowing out your shocks, you should be fine at that height. If you go really low, the upper A arm can smack the front shock tower on bad bumps but at 2.5" you won't have that. Also read the sticky thread about not needing camber kits for some info on that :thumb:
PostPosted: Wed Apr 11, 2012 9:40 pm
by jadeydrag0117
i see, thanks man.
yeah i read the thread about not needing cambers a long time about :thumb:
PostPosted: Thu Apr 12, 2012 12:54 am
by known
Lowering your car will cause pre-mature wear to other items in your suspension as well as wheel bearings.
You have to remember you are completely changing the original geometry, not a bad thing but keep it in mind.
Bushings, balljoints, and wheel bearings should be checked frequently.
You most likely will be fine, I daily drove a lowered Civic for 8 years so I experienced what items wore out faster after replacement than others, like bushings.
PostPosted: Thu Apr 12, 2012 12:59 am
by jadeydrag0117
yeah i was going to do this anyways :) because i noticed some other bearings were worn out, thanks...
...so basically i should only start getting suspension parts if i get a stronger engine..
