- Sun Aug 23, 2009 1:01 am
#139306
ok im having some issues with my brake pedal action and feel since my swap, i just swapped brakes and traling arms, and added new pads, i still have the stock prop valve and mc/bb. but my pedal is soft and low, but feels fine as the pedal gets fully depressed, the fronts seem to get alot more brake force then the rears. so im asking what can i do to get my brake pedal back where it should be and get my brakes to work as evenly as possible. btw all 4 wheels were properly bleed and there is no air in the system.
adding rear disc dont help that much, it more for looks
then anything.. unless ur pushin like super crazy HP
check for a leak around the BB the paint should be pilling if its leaking,
you prob need a prop vavle for the ex
hope i could help
