Brake Problem. Makes a noise
PostPosted: Mon Mar 08, 2010 1:01 am
by JoseEJ1
Ever since last week, everytime I brake slowly, the right front brake makes a noise until I come to a complete stop. Its not a grinding noise. Its Like as if something is hitting against something. I took off the wheel to see but everything looks normal. I thought something was loose.
But when I brake hard, it doesnt make a noise at all. Like sometimes it does it, sometimes it doesnt do it. I don't know what it could be..? Rotors? Im pretty sure its not the brake pads. Sorry Idk how to describe it that good. Hopefully you guys know what I mean. :?
PostPosted: Mon Mar 08, 2010 2:16 am
by Apexracing
your caliper is probably frozen, or the slide bolts that go from the caliper to the mounting bracket are frozen or out of grease. take your wheel off and remove the pads and check your caliper for signs of corrosion or rust.
