- Thu Apr 15, 2010 7:55 pm
#188006
i was wondering...what 4 piston calipers will work on a eg..besides aftermarket calipers, do honda make 4 piston calipers for any of the later models civics? or type Rs?
Why do you want/need 4 piston calipers in the first place? Just upgrade to Integra brake parts and you'll have an EG that will stop on a dime. If you can afford it or find a set, get the 5 lug ITR swap. Bigger rotors, bigger pistons in the calipers, and more pad surface area than the LS/GSR brake setup. You just have to make sure to get the ITR master cylinder if you get the ITR brake setup. It's a 1" MC, versus the 15/16" of the LS/GSR and the 13/16 of the Civic.
