rear disk upgrade
PostPosted: Tue Feb 15, 2011 1:35 am
by blk92hb
ok so i have been doing some looking online and found a rear disk upgrade using factory parts. it uses a rsx caliper braket, ep3 disk, and ep3 or rsx pads. but you use the factory calipers. the only problem i see is that the ep3/rsx pads are longer then the eg calipers.
so the question is has anyone done this upgrade, and if so can i use a ep3/rsx rear caliper insted of the eg. just so i dont have uneven wear on the pads and rotors.
