- Sat Aug 11, 2012 10:42 pm
#313295
so i have the rear trailing arms from a 96 teggy its going into my civic lx im missing the emergency brake cables i have the chance to remove the cables from a 4 dr 95 special editon will the line work with the integra brake set up?
ej2?? wrote:so i have the rear trailing arms from a 96 teggy its going into my civic lx im missing the emergency brake cables i have the chance to remove the cables from a 4 dr 95 special editon will the line work with the integra brake set up?
As long as they are rear disc on the 95 civic then yes it will work other wise no, if you have a 4 dr integra 4 dr cables would fit the best if you need to find some.
