- Wed May 14, 2008 11:59 am
#55292
Sounds like you've got lots of air still in the system...
As for the X thing your friend was talking about - yes thats true, your front left and back right brakes are seperate to your front right and back left - thats incase a brake pipe or some other brake component fails, you would still be able to stop as in the worst case you would only loose brakes on 2 corners. Thats the same for every car though i think and doesnt affect the order you bleed your brakes
But you dont have to bleed your master cylinder - just make sure its topped up while you bleed your brakes as you dont want the fluid level to drop far enough that air could get sucked into the brakes!!
