- Wed Jun 25, 2008 3:51 pm
#59740
I have set of S2000 front calipers in my basement waiting to go on my car. You have to use RSX-S calipers redrilled to 4X100 to make it work. I'll assume that means both use 11.8" rotors.
- Sat May 22, 2010 6:48 am
#196117
Bringing back the dead. I have done this. You need:
1. JDM ITR or CRV knuckle (32mm USDM ITR knuckles cannot support proper bearing)
2. 97-06 CRV or RSX front wheel bearing
3. 32mm spline with base RSX hub or 36mm spline with RSX Type S or 02-06 CRV hub (97-01 CRV hub too wide both for center bore and outer hub diameter)
4. RSX Type S front rotor (thicker TSX rotor will work with 1mm washers to push RSX-S/S2000 caliper bracket out)
