Tire Size Calculator
http://miata.net/garage/tirecalc.html
The http://Miata.net link above has a calculator to help you determine what width and sidewall tire you will need to use when buying larger rims to keep the same outside diameter.
(p.s. Miata rims are also 4x100 and I've seen them used on civics
