- Sun Aug 24, 2008 3:49 pm
#67173
I think I can get all of the rubber off and not need the body filler. I really hate that stuff.
Actually I think I just need to get new ones. The rubber lip that butts against the glass is all cracked up as well.
- Tue Aug 26, 2008 7:39 pm
#67401
i have a ?... how would it turn out if you did this to the door and fender mouldings??? and how do you take those off.
- Tue Aug 26, 2008 10:43 pm
#67406
I would use a self etching primer. You can get it at autozone or similar places.
slm01 wrote:When doing the windshield wipers, do you have to use primer as well?
- Tue Aug 26, 2008 10:44 pm
#67407
You could do it to those too
You have to get to the clips from the inside of the door after removing the door panels.
jdmtuned231 wrote:i have a ?... how would it turn out if you did this to the door and fender mouldings??? and how do you take those off.
- Wed Aug 27, 2008 11:36 am
#67451
Thanks a ton man. There are the only two things i need to do to the wifes car to make it mint again. And your write-up has done that for me.
teal_dx wrote:jdmtuned231 wrote:i have a ?... how would it turn out if you did this to the door and fender mouldings??? and how do you take those off.
You could do it to those too![]()
- Sun Jan 25, 2009 4:29 am
#92209
thanks alot. i'll be sure to try it this weekend.. been wondering how to fix those things.. btw.. my wiper arms are in the same condition, is the process the same? how would i remove them? thank you
- Tue Jan 27, 2009 12:46 am
#92525
I did mine with a product called leather luster. The good thing about this stuff is it is rubbery to the touch much like the old trim was. This product stays put and will not dry out or fade. check out the pictues.
(o0)\(III)(III)/(0o)
- Tue Jan 27, 2009 6:49 am
#92616
That looks awesome, Where did you get it?
