- Fri May 18, 2012 10:36 pm
#305378
for this you will need pliers, flat head screwdriver, and super glue.
first you will need your regular bulb that was in you headlamp
[/img]
then you will have to remove the bulb and leave the outer metal ring to hold your HID, i used the pliers and broke the bulb and tore everything out
then if your wires was like mine and had 4 wires together with a rubber piece
you will have to cut the rubber piece so you have the wires to the bulb away from everything else
then you will need to slide the bulb wires through the metal ring and take the super glue and put a bead around the metal ring and put the bulb to the glue and let it dry
if the back of your bulb is like that you will have to tear off the prongs that plug into your wiring for your high and low beams and ground and then tap a hole in it big enough to fir the connectors through
and once you have done all of that you will be able to hook the HID up in your car and they will work just be very careful with the bulb
one HID in
and the second bulb installed
[/img]
one HID in
