Sticking Hood latch
Sat Jul 19, 2008 5:27 pm
by Gorveatt
I had this issue with my hatch, and am developing it with the Teg too, the hood latch seems to preventing it from shutting properly, was a bitch the other night in the walmart parking lot trying to shut my hood and it wouldn't shut
if you push the cable with a screw driver it allows it to shut, anyone know a fix for this? I was thinking just spray the hell out of it with rust check or wd40
Wed Jul 30, 2008 12:02 pm
by BreCalmor
My 95 Civic has had this problem for years, but all of a sudden, the stupid VA state inspector failed my car for it...
Anyone have a quick fix for this?
I have tried finding a replacement cable, but none of the online parts places have the exact part.
Anyone replace it and can tell me how hard it is?
Thanks !!
fix
Mon Jan 18, 2010 3:52 am
by 94delsoltyper
spring on the back closest to the radiator needs to be replaced with a stronger one, same spring that pull the little handle back into place
Mon Jan 18, 2010 4:07 am
This happened on my EK until one day it wouldn't release to open. I had to go up under the bumper, what a PITA that was.
I tool it off and lubed the hell out of it and it's been good since.
Tue Jan 19, 2010 12:06 am
by dawg316
teal_dx wrote:This happened on my EK until one day it wouldn't release to open. I had to go up under the bumper, what a PITA that was.
what lube did you use. my eg has a problem with the hood not latching properly and its the same spring. i used wd-40 on it and it worked for a lil bit now its back again
Tue Jan 19, 2010 1:42 am
I used PB blaster to break it loose and then moved it a lot to break it in. Then I put some Tri-Flow lubricant on the latch and it's been good since
Tue Jan 19, 2010 2:14 am
by edcortez9
yeah its the spring that doesnt work anymore i shut use to shut my hood really hard each time and it works like that but imma just replace the whole latch when i paint it .
Mon Jan 25, 2010 5:23 am
by marquisdee1018
teal_dx wrote:I used PB blaster to break it loose and then moved it a lot to break it in. Then I put some Tri-Flow lubricant on the latch and it's been good since
Yeah I just shot my with pb blaster and it hasn't given me any more problems.
