- Sun Jan 25, 2009 10:54 pm
#92315
peel off what you can of the tint then make sure you take any interior pieces out cause I found that spraying a little 87octain on the adhesive and then use a razor blade and it just comes off like there is sticky jello on the window, But when I did it the window was out of the car but it was very easy, I would think if you put the fuel in a mist bottle it would work well but I was suprized how easy it was to get off, if you don't want to use gas I would think Acetone would work very well to. I know it wouldn't smell as bad...
I would try some less harsh/smelly/flammable ones first.
Shitruiners Inc.
