Ride of the month nominations & voting.
Whose civic should be ride of the Month?
22
42%
10
19%
7
13%
14
26%
#334574 1. HiTec
EG8 DXi:
Body/exterior:
- Rusts, dents, plastics; fixed
- New paint from Frost White NH-538 -> SuperBlack
- Coupe front bumper
- OEM Headlight washer system
- Coupe/HB Spoon Style carbon fiber electric sidemirrors with home made adapters/base plates to replace the original manual adjustment mirrors.
- Yellow fogs with 3000K Xenons, Slim ballasts.
- OEM foglight harness and switch
- JDM Stanley OEM flat sidemarkers
- Amber corners
- SPEC-D headlights...
- ...with Morimoto Mini H1 5.0 LHD projector retrofit
- OEM electric headlight adjustment motors retrofit to modified SPEC-D headlights, OEM-wires added to cars main harness with help from Honda wiring schematic.
- 6000K H1 Xenon kit with slim ballasts
- 50/50 Red/Clear tail lights with modified OEM tail lights base -> perfect fitment.
- Roof and pillar antenna removed.
- 60pcs of Skunk2 purple fender washers around the car.
- PasswordJDM purple battery tie down
- Wings West RS style polyurethane front lip.
- EK Sedan -98 side skirts
- EK front splash/mud guards
- EG rear splash/mud guards
- "OEM" Towing hook removed
- PasswordJDM golden colored rear tow hook
- Tinted rear windows 35%
- Tinted front side windows 50%
- Corollan trunk spoiler(?) , I don't know for sure cause it was allready installed to the car when I bought it.
- Color coded door handles
- Thin JDM side moldings
- Window visors.
- SuperFlux LEDs in park lights and corners.
- AVITAL 5303 alarm/remoter start + couple of additional sensors.
- DEI 530T window automation module to front windows (I will be adding the module to rear windows too).
- Some wire tuck work inside the engine bay
Interior:
- BRIDE Gias Low Max Replica front seats.
- Color change from grey -> Black
- OEM black leatherwrapped 4-prong NON-SRS steering wheel with Cruise Control buttons
- JDM Optional Arm Rest (Highrise version)
- JDM Optional Audio Center Console
- JDM Automatic Climate Control conversion
- CDM/USDM OEM-Cruise Control retrofit
- Password: JDM leather shift boot
- BLOX Neo Chrome shift knob
- Broadway Flat 240mm mirror
- Complete power windows swap using original Honda parts from ESi. - All center console/"AC"/switches/cluster lights changed to LEDs.
- Custom made mirror inner plates tweeter adapters.
- Dyed the carpet to black (I think im gonna change it to red(?))
Chassis/Brakes/tires/rims:
- BC Racing BR series coilovers with 10kg/mm & 6kg/mm spring rates. - Nangkang NS-2 205/40/16 tires
- Advan Replica 659 Gold 16´ rims
- Muteki SR35 NeoChrome lug nuts
- Genuine ASR rear subframe reinforcement plate
- ASR 24MM rear sway bar
- ASR endlinks
- Skunk2 Pro Plus camber-kit rear
- Skunk2 Pro Plus camber-kit front
- D2 Racing TOE-kit
- Function7 Lower Control Arms
- DXi drums -> VTi disc brake swap to rear (BrakeMax pads) - Sodablasted + red painted trailing arms
- Sodablasted/black painted brake shields
- Energy Suspension red trailing arm polybushings
- Goodridge stainless steel braided brakelines front and rear
- 282mm / 25mm drilled&grooved MTEC brake discs front (Rover MG ZS discs)
- 17CL15VN Integra Type-R front brake calipers
- Honda NSX front caliper carriers (other carriers don't accept 25mm thick discs without mods)
- EBC Greenstuff front brake pads
- EG9 SiR front hub swap
- BuddyClub extended lower ball joints
- 1´ ITR master brake cylinder & booster combo
- ITR 24MM front sway bar
- ITR front swaybar endlinks with Energy Suspension polyurethane bushings
I.C.E.
- Pioneer 2-DIN AVH-X5500BT headunit (2013 model)
- Pioneer TS-E170Ci in front and rear, 2,5mm2 wirings all the way.
- Autostudio 4 channel T-480 amplifier to the Pioneers (with 15mm2 power lines)
- Pioneer GM-D9601 (2013 model) amplifier to subwoofer (with Audison 25mm2 power lines)
- Optima YellowTop 38A battery
- Rainbow Cyclone 12 subwoofer
- Audison Connection FT2550 RCA-cables (3 pairs)
- Silent Coat 4mm (12m2) sound deadening mat to...hmmm. basicly everywhere?
- Behind front door mids: 15mm thick honeycomb looking Silent Coat Sound absorber
- Rearview camera with IR night vision
- B18C-R in slow building stage...
http://civic-eg.com/viewtopic.php?t=22709
2. fago88
3. bigJOE671 1994 Si
94' Civic Si
JDM B16A
short ram intake
high flow cat, 2.5 cat-back, but with a stock muffler, that's how it came with the car
work done since i bought the car:
-installed sound system
-tinted windows
-8000k HIDS
-window visors
-installed MSD ignition
-Installed a whole AC system
-Painted car...Ivory White with Blue Pearl
future plans:
-Chip ECU and learn how to tune
-install carbon fiber mirrors
-Duckbill wing
-fog lights
-new rims, choices are: volk te37, BBS rs, Mugen m7, RPF1's or Work Equip 03
-Clutch and flywheel
-b20vtec
-Header
-Cat-back exhaust
4. Trippsol Cypress Green 97 Honda Del Sol VTEC.
By fitimio
#334582 WOOooowww, these cars are immaculate. I like the eg9 because I have never seen a cleaner 4 door in my life.
By jesusali
#334583 we need some fully body pics of Fago88!
Bykutthroatkrow
#334591 Gotta go with the sol Tec. The first sedan is a very close second
By PGB
#334602 Gotta vote for Hitec.
The other cars are beautiful and its def gonna be close but I've been waiting a long time for him to be able to take part in this.
I'm not even sure that mod list does it justice.
Good luck brother.
By FG2_Andrew
#334605 decisions, decisions.
Brandonthesmith wrote:this is a tough one honestly, that del sol and the eg8 are both emaculate.... i really don't know.
That's exactly what I was thinking...
By Apexracing
#334611 K series did it for me. Tripsol if you ever sell that car i hope i can buy it! :thumb: :thumb: :thumb:
By eg-guy
#334701 Sedan, coupe, hatch, and delsol!! All are very nice cars :thumb:
By fago88
#334726 why is my car here to vote? and why so shit pics?????? oO
I have better one :(
By *EvE*
#334729 I had to give my vote to the sedan but that del sol is very clean...i wanna vote twice :( ...lol good luck to everyone!!!!
fago88 wrote:why is my car here to vote? and why so shit pics?????? oO
Because your car is hall of fame worthy :)
Pics were the latest from your build thread at the time. :thumb:
If you had a modification list in your build thread, that would have been included too. :thumb:
By EjWone
#334932 All worthy vehicles! Voted.
