- Sat Jul 10, 2010 12:13 am
#203953
Yep if it cranks but wont start more than likely its the immobiliser. Think it cuts 2 circuits, injectors and something else from info i found.
If its been locked by key then remote pressed it'll arm it. If you then open with the key it'll not set the alarm off but it'll be immobilised (This happens everytime i get it from my mechanic as he uses the key and i use the remote lol ).
I have a red LED on top of the steering wheel that flashes when armed yep but in day light looks off so have a closer look. If it is flashing then once your in the car just hit the remote once and it should remove it .
If its not flashing its not immobilised and problem lies elsewhere.
Its a good system , has bonnet release sensor and you should see 2 little stalks either end of the dash which are the shock/impact sensors.
It'll arm itself if you disconnect and re-connect car battery too .
I don't know about the glove box lock though i dont have it , could be an aftermarket kill switch? Pic would be interesting.
You got some nice bits on that car, i got the remote lock security system , optional Honda alloys and previous guy just put on 4 new Pirelli's , installed rear speakers and hide away cd player so although i half wanted an ESI for just £550 there were too many goodies (minus A/C lol).
Yours is in good condition bodywork wise , mine is Red and lacquer peeling off and bad arches but it lived by the coast for about 10 years which can't have helped.
i'm in hospital over 2 monhts....i hope i'll get out soon and get that photo....btw, i'm so jdm colored YELLOW!!!! DAMN HEPATITIS A!
