- Tue Oct 05, 2010 2:37 pm
#216946
thank you for contributing and welcome to the site.
DLC wrote:Sorry guys, but you can't drill (or cut) tempered glass. Any cutting or drilling of the glass will cause it to explode. I worked in a glass factory for 12 years and drilled thousands of pieces of glass. If the glass requires a hole, the hole must be drilled before the glass is tempered. You may be confusing safety glass (the type used in windshields with plastic sheet sandwiched between two untempered pieces of glass) with tempered glass.
