- Thu Oct 01, 2009 3:55 am
#148384
was it a new or used dizzy?
- Thu Oct 01, 2009 3:58 am
#148385
grabbed it off a 92 si. had over 300,000K
if i replace it what will happen?
cause my car still runs good when its bumped
or is it not getting the spark from turning over staying still?
please get back to me and i will pull one tomorrow
- Thu Oct 01, 2009 4:02 am
#148387
yea chances could be that the distributor just isnt creating enough spark under the rotational speed of cranking the engine over. and bumping it forces the issue. i would say a dizzy with over 300k might be the problem.
- Thu Oct 01, 2009 4:07 am
#148389
probably the whole unit sense the coil inside is probably on its way out, if the cap and rotor were bad the engine would run rough.
- Thu Oct 01, 2009 4:16 am
#148392
yea no problem im sorry im not very clear, im not a mechanic by any means, but ive been around hondas since i was 16, just recently ive really started to get into them and start building and working on them. but im getting a good feel for them.
- Fri Oct 02, 2009 2:50 pm
#148604
thank you everyone for the advice!!!
went to the yard and pulled off a dizzy went back to put it on and when i looked at my old one the rotor was toast!!
bought a new cap and rotor for mine and it fired right up!!!
anyways i took it for a spin runs pretty good
still have a problem though?
when i stomp on it it will still sputter, like its miss-firing
could i have bad timing? or what?
- Fri Oct 02, 2009 2:54 pm
#148605
did you put new plugs and wires on also, now would be a good time to do it. congrats btw, glad it kinda helped.
- Fri Oct 02, 2009 6:06 pm
#148645
if you follow the directions with the timing light i dont see why not.
- Fri Oct 02, 2009 6:25 pm
#148648
could be due to getting flooded out, if the plugs are shot, or if the wires have alot of resistance.
- Page 4 of 4
- 1
- 2
- 3
- 4
