- Tue Aug 11, 2009 1:38 am
#137170
ok just got this civic and the driver door lock is acting weird. it will lock only when i hold the door handle to the open position from the inside. If I am not holding that then it will not lock.
- Tue Aug 11, 2009 1:40 am
#137172
they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
- Tue Aug 11, 2009 1:42 am
#137173
Yea but then why wouldnt I be able to lock it from the outside with the key? forgot to add that part i have to lock it from the inside.
eg_turbo_hatch wrote:they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
#137174
that hasn't stopped me on a couple occasions
- Tue Aug 11, 2009 1:46 am
#137177
are you trying to lock it with the key with the door open if so try with the door closed and if there is still a problem maybe the lock rod isnt hooked up the the lock cylinder in the door?
MarinePoolee wrote:eg_turbo_hatch wrote:they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
- Tue Aug 11, 2009 1:48 am
#137178
It doesn't let me lock it with the door locked either, but correct me if I am wrong wouldnt if the lock rod wasn't connected wouldn't the door not unlock from the outside with the key like it does?
eg_turbo_hatch wrote:MarinePoolee wrote:eg_turbo_hatch wrote:they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
- Tue Aug 11, 2009 1:52 am
#137182
yes your correct if it wasnt hooked up it would not lock or unlock i didnt know it would unlock just not lock im not sure then
MarinePoolee wrote:eg_turbo_hatch wrote:MarinePoolee wrote:eg_turbo_hatch wrote:they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
- Tue Aug 11, 2009 1:54 am
#137185
Ill have to look more into it and wait on more replies
, thanks for the try tho man
eg_turbo_hatch wrote:MarinePoolee wrote:eg_turbo_hatch wrote:MarinePoolee wrote:eg_turbo_hatch wrote:they do that so that you cant lock your keys in the car. if you close the door it will lock from inside otherwise you have to hold the handle
- Tue Aug 11, 2009 3:47 am
#137207
I like them, I always lock then doors from inside, Just hold the handle open and press the lock down, In Coupes and Hatches its easy as they are right next to each other. I can do it one handed. In the Sedan its a little harder as they are farther apart and you need both hands for it.
Its not just an EG thing. My EK Hatch and DC Integra Hatch do the same thing.
Once you do it long enough its habit.
- Tue Aug 11, 2009 4:39 am
#137216
I'm glad yall just deal with it I fixed it =]
- Tue Aug 11, 2009 5:34 am
#137231
Well thanks but its fixed now, locks and unlocks from the outside. Yea im just that good =]
GoRide wrote:Even the newer ones do it my friend 05 locks the same way.... just a normal Honda thing!
- Tue Aug 11, 2009 5:39 am
#137232
what was the cure
- Tue Aug 11, 2009 3:19 pm
#137251
Excuse the back explenation cause im new with cars, but I just removed the door panel, and when unlocking with the key the rod would move fine but when i locked wit the key it moved a lil then was jammed.
Solution: WD40 and brute force.
eg_turbo_hatch wrote:what was the cure
