- Sun Jan 03, 2010 6:19 am
#165450
Only good pic I found on google.
Assuming this is the HKS Super Mega Flow Reloaded Intake. I would pass myself.
Not only do they look super uncool sitting in your stock hose. (or any cheap tube) you wont be getting a true cold air intake, not even higher flow, just a different air filter.
If your going to redo your air intake, Get a AEM v2 Cold Air Intake, Larger Pipe, and is a true cold air intake. This has been engineered to get you better performance throughout your power band.
If you want to get a cheaper solution, Get a generic cold air intake pipe and cone filter. Its larger piping and will give you better air flow. On Single cams you can hear vtec pretty good with them as well.
