- Thu Apr 29, 2010 9:36 pm
#191035
Okay so i changed the clutch master cylinder & slave cylinder already (Both New). While partial/half way through bleeding/pumping the clutch pedal drop to the floor WTF......(Pedal is suppose to drop to floor ONLY when the slave valve is release) So i have someone pull the clutch pedal back up to Normal postion & press it back down again & While i was up front listening i can hear air leaking through the seals of the Slave cylinder......I'm thinking maybe i was giving a bad Slave cylinder, but the seal looks very good........But
I called AutoZone again so they should have a Slave cylinder replacement by tonight......I should be able to try bleeding it tomorrow again....If same problem arise..I'm done for & probably taking it to the shop.......
If i can hear air leaking out of the Slave while the clutch is being press down...I'm sure air is some how passing these 2 seals??????? But shouldn't air be coming out of the bleeder valve instead of pushing air pass the 2 seals below.....
***Note: Seems like the clutc pedal is not even getting really stiffer as i am bleeding some how, maybe this can be a problem why air is some how leaking at 2 seals***
Thanks In Advanced Ricer's
